decoupe
(deceased)
This is also posted on the 2002faq.com forum but I thought someone here might have run into this as well - not that I would wish this on anyone..
I'm struggling to get the carb set up on my '76 2002 stock engine with 38/38 downdrafts and given the similarity with the m30 and the number of e9 weber downdraft conversions, I'm hoping for advice.
You can see that plug #1 is sooty to the point of fouled, #2 is lean to the point of knocking #3 looks just about right and #4 is showing rich - and this is a new set of plugs. Using Best Lean Idle setup procedure with 45 150 185 jets, it drives but not well and within minutes it's missing and jerking at any rpm and #1 is fouled with #4 on it's way as well. Same thing happened when jetted 50 145 185. Going one range hotter to NGK BPR5ES and adjusting my float level to spec I hoped I had resolved my set up.
No luck.
So everything is new with less than 500 miles on it and the timing set with ignition at idle (900rpm) 12 BTDC. Starts like a champ and the electric choke functions just fine.
So what combination of air, fuel and spark produces over rich on #1 and 4 and lean on #2 and 3 ?? One carb feeds all 4 sparks from a common source - fuel pressure regulator in place. Coil is newish Flamethrower and points replaced with Petronix.
The same air/fuel mix is being supplied to each cylinder but with very different results so is the problem is electrical? Replaced the plugs had no effect. Replaced the dist cap with OEM had no effect. Checked for spark and all four showed good spark.
Distributor? Is it possible the distributor is so worn that there is a wobble and instead of circular it spins in an ellipse? How to test that?
Grrrrrr
No luck.
Grrrrrr
