503recheck
I have a 85 m30b34 out of the car for rebuilding with the manifold 3.2/3.4 which I think is motronic 1.0 without knock sensors and a schrick 284 cam. I want to run 1.3 with wrecking yard parts of front dampner/trigger, complete manifold (stamped with 3.5)with wiring harness and engine computer of (179) from a 88-90 535,635.735. I also want to run a mafs instead of a vane system. I realize I should have started with a m30b35 but am commited to the b34 now. Does the 85b34 have bolt holes in the block for the knock sensors of the 1.3 system? and are there any problems with the intake ports matching between the two intake manifold systems. Any other problems that I have not mentioned that I will need to consider?. thanks for your time
