a couple questions on auxiliary fan wiring and sensor
mark99
Kirkland WA
Don L told me later cars had a temperature sensor in the radio
I will have the shop that is rebuilding mine add a fitting, he said it is no problem
Could someone explain where that fitting should be located? a couple photos and dimensions?
Second, how do I wire it in so that the aux fan comes on with the AC and with a temperature input?
I assume there is an electrical component I need to source
(and that keeps the fan from inoculating on and off?)
Don probably said in the radiator not the radio.
There is the aluminum radiator that Don created for the E9 and includes the temp sensor setup.
With the original radiator I think it would be triggered by dual temp sensors on the engine side of the cooling system.
radio, that's funny
I talked to Don about the alum radiators but none ready at this time or I would have gotten one
He said, hope I don't misquote too badly, early cars, switched on by AC only, later sensor in radiator
so still looking for location and wiring / components
I posted the diagram recently with the diode
Here is the wiring diagram for initiating the aux fan (3) with the a/c temp switch (5). If you car came with a/c, this should be how your car is wired.
The diagram Chris posted is an add on to this circuitry that uses the temp sensor as an alternative method of initiating the aux fan when the a/c is not operating.
Using a Spal fan and was strongly considering wiring it so it would also come on with H2O temp
Chris, Where did your diagram come from? It appears to be 74 and later without the bypass relay in the 73 and earlier coupes with the four pin fan switch.
Chris - I actually grabbed this off the forum a while back; not sure of the source. (You perhaps?)
I posted that because of Mark's reference to "later cars" at the beginning of this thread. Here is the material I have for a 72:
