bmw art car
I spent the better half of the day trying to figure out why i can't seem to get the carbs balanced and running half way descent.
i did find out that the rear carb (the one close to the firewall) had a stuck 2.nd barrel butterfly. i got it unstuck finally.
but i also noticed that the idle lever doesn't go down as far as the lever on the front carb.
and the idle mix screw can be tuned in at least half way before it even moves anything. that seems wrong compared to the other carb
so with all the stuff and trying the closest i got to 700-900rpm idle speed is 1500 rpm. its either that or the car will run so crappy, that one isn't sure whether it's a straight six or a tractor.
i wonder if i shouldn't get some weber i can get the manifold and two of the triple weber from my friend.
they don't need to be hooked to the coolings lines , right?
i don't like that part anyway. good things always seem to be the least complex devices.
is a new weber set up the way to go? or try to find some rebuild zenith
and hope to spend some friday afternoon driving the car instead of getting asphyxiated .
