Guys,
i just got a set of hella 71156 H1 headlights. unfortunately, the instructions were for h4 lamps ... which i already have. so here's my question, i see that the connectors don't match our plug ... although the lamps do come w/ 2 separate wires.
here's my guess, you push the 2 wires thru the rubber cover, place the wires on the plugs ... then plug into the harness.
here's my question, there is a white wire and a brown wire. i can figure out where they go on the wiring harness ... i just don't know which one goes to the bulb and which goes to the other spade connector.
a 2nd question - what do the instructions recommend for getting the spade connectors thru the rubber cover
if you know this, please let me know ASAP
thanks
scott
thanks
scott
