AC Belt Size for Sanden?
Luis A.
Wisconsin
Haven't found this on any of the great AC threads we have here. For those of you running a Sanden-style compressor, what size belt are you using and what is your compressor mount arrangement? Is the belt size the same as the York/OEM belt size?
I use a Gates 9330. I have a Sanden on a York adapter. Easiest thing to do is just get one to fit for your application in that width (.47" or 12mm), I fit mine by getting the size that takes a slight amount of effort to get on the loose compressor and doesn't need much movement to tighten, I want the shortest belt practical. Just return the ones that don't fit.
I have ordered a couple of sizes of Kevlar reinforced belts (won't stretch like polyester reinforced belts) for my Sanden installation. I'll post what 'fits' when I get them here. But - mount will probably make a difference of perhaps a half inch or so in length.
