coupe74
1) Is there any way to access the gauge instrument cluster ground, or fuel gauge ground, to add another ground without pulling the dash? I have no speaker cover to fish through as it was covered up by PO. 1974 CS FYI.
The purpose is to try to fix an erratic fuel gauge and signal indicator lights.
I can't find this in a forum search, so maybe because the answer is "no"?
2) Alternatively, would disconnecting the tank sender-unit keep the gauge from beating itself to death in the interim? Since the gauge is not working anyway, usually.
3) In case of "no" to #1 and "yes" to #2; has anyone tried making a fuel dipstick to use through the filler pipe? If so, what did you use for the dipstick? (I do this on my 1956 International Harvester pickup with a wooden stick marked in 5 gallon increments. If you think coupe parts are hard to find, try owning an old IH!)
Thanks.
Thanks.
