So, I would like some input from the tribe about gauges.
I've acquired a VDO oil pressure sensor that contains a pickup for the gauge and a connection to retain the idiot light. I am planning to install this on the head in lieu of the existing idiot light sender.
I also have a VDO oil temp sender, and I was thinking about installing it into the housing that attaches to the block and holds the oil filter and canister. In order to do this, I would need to remove the housing from the block, and then drill and tap the hole. Given that I have all the vacuum hoses and radiator hoses disconnected, this would best be done now. Whilst planning to pull this baby off, I was wondering if there an upward oriented filter canister that fits the M30b30? My son's e34 has an upward oriented canister, and changing the filter without making a mess is easy.
Lastly, I have read that the stock water temperature gauge provides slow feedback on engine operating temperature. Do people install aftermarket temp gauges because of this? Could an aftermarket VDO sender fix this using the stock gauge?
