Aero Kroil deal
This is good stuff.We used it regularly at work until someone complained about the smell.The only negative aspect is that if you leave it sit in a regular old squeeze handle oiler can it seems to rot the rubber gaskets.It also seems to clog it's own nozzle in the spray can,especially if it gets cold.I bought a gallon jug of it years ago,on sale, and pour it into a little plastic squeeze bottle to drip onto bolts etc.
I've never had a nut that wouldn't come off after using Liquid Wrench, available everywhere
PB Blaster is another one that works well and is readily available, it's smell is not so appealing either.
I've been using ATF w some acetone mixed in. ATF seems to have an ability to infiltrate itself via capillary action anywhere. I've noticed it even creeps out of a capped bottle onto the outside.
