afm to maf conversion help
fidosd9
New Member
I currently converted my car to run motronic 1.3. I also want to convert to Mass flow anybody done this? what are the options i have. thanks
i running both
im running millers maf and war chip. still havnt dyno'd since install, but my guess is + 10-15hp - def noticeable. idle is also sig smoother vs oem barn-door maf. spendy though - i think around 800 bucks. chip is programmable, but nothing compared to mega squirt - if i was doing it over would prog go that route - lots of threads here on that.
Miller gear
Replacing the AFM with the Miller MAF, which comes with its own chip, will get you "gains" similar to one of the better chips (Conforti, D'sylvia, etc.) on its own. It will also provide better throttle response. No need to get the warchip unless you have other mods that can take advantage of tuning.
My $.02.
