Air pressure sensor location
It mounts on a bracket with the relays right above the steering column.
Be careful with that sucker -- they are fragile. All it takes is a backfire to render it completely useless.
In the engine bay or the drivers' compartment, because i can't find it.
In the engine bay, but I misspoke. Its actually on top of the brake booster mount, I believe -- not the steering column. I couldn't find a good picture, but maybe this will help. It should be mounted back near the firewall, next to and below the coolant reservoir in this picture. You can see the hose, but not the sensor.
