An old car will often surprise you, and indeed Annabelle had another surprise for me today.
When last I ran Annabelle, my brake booster wasn't boosting and my battery was fat and hot.
As to the battery, I had thought I had perhaps allowed it to discharge too fully through careless storage. I was planning on a really small Odyssey battery in the trunk anyway, so I decided when the old battery spit sulfuric acid all over the inside of my engine compartment (great fun that) to press ahead with the trunk battery. Having wired that up, I started her again, hoping to tinker with the carbs.
But just for the heck of it, I measure my system voltage at the battery and found 19.34 volts! I understand AGM batteries to be senstive to high voltage charging, so I shut her down immediately.
Age and condition of the alternator are unknown. Also, I am not sure about the output amperage and don't want to run the car to test this. So, rather than seeking to repair the voltage regulator, I am thinking of replacing the entire alternator, and upgrading to a higher amperage. What have others done here? Are there uprated (say 80 amp) alternators that bolt up to the original mounting brackets in the 3.0CS?
