(another) free 3.0l engine- Vancouver BC
aalto
vancouver
I have a 3l engine that was extracted from my coupe this summer. The bottom end is solid as far as i know. It ran quietly and smoke-free until the timing chain guides disintegrated allowing the chain to skip. The head (which i believe is a replacement from 1979) has two broken rockers, a worn camshaft, and several bent valves (due to contact with the pistons). There are no accessories attached to the engine and no oil pan. I did a basic cleanup of the block and head so both are not coated with oil.
If you live in the vancouver BC area and need any of these items as a core for a rebuild they can be picked up from my garage. Otherwise they are going to the scrap man!
