E9Paradise
I recently bought a '74 3.0CS. It won't idle smoothly and it backfires through the rear carb. The carbs are stock Zeniths. The timing has been set and seems to be steady. It has new plugs, wires, cap rotor. Points are in good shape.
Observing a vacuum gauge on the rear manifold shows a very erratic and inadequate vacuum. I haven't compared to the front manifold yet. There is a lot of carbon around the rear carb intake and evidence of heat. It can run smoothly while driving but will occasionally backfire through the carb then as well.
I'm wondering what might be the problem. I suspect a vacuum leak on the rear manifold... Anybody have any other thoughts?
Thanks! John
Thanks! John
