acat2002
I was hoping to short-cut some lengthy circuit testing by tapping the experience on this board.
The problem is this....
After re-installing the fuse in position #4 (to work the clock and interior light), the battery drains very fast (within 4-6 hours). The dome light turns off and I disconnected the clock, yet the bettery still gets sucked dry. Now I guess I know why the PO had this fuse out :cry:
I see by the wiring diagram, it appears that only a few devices run from fuse #4, such as rear luggage light, clock & interior lights. Wiring diagram also shows a lead running to the hazard switch. I haven't checked the luggage light, but if I remember there is no bulb in there, so I didn't think to look in that direction.
the basic question is...
If after eliminating the clock as a culprit, where is the first place you'd look for a current drain?
Anyone have a similar experience?
I'm trying to avoid removing the fuse panel to expose the rear. Working in that tight space with thos hardened wires is a total PIA! I do have the dash removed, so I guess now is the time to address this issue.
