RogerB
My coupe recently stared turning over slow when starting. Then it would not turn a full round but just "bump" . The battery was six years old, so I suspected it. I took it to NAPA and has it tested. It tested good. Brought it home and reinstalled with same result. I charged it to 100% with no change, so I bought and installed a new battery and still no change. I had an idea and connected the negative pole to a jumper cable and the other end to the block. Bingo! It turned over fast and started as it should. I had a new pretty copper ground cable I had purchased off of here a while back and installed it. I cleaned the factor mounting area on the fender although there was no sign of corrosion and installed it. Still no turn over! I checked the ground strap on the fire wall as best as I could loosen and retightened it. Same result: no turn over.
I don't want to add another ground cable from the battery directly to the engine, so what am I missing here?
I have owned many coupes, and the factory ground on the fender has never been a problem. Thanks for any suggestions. RB
