beginning of extra parts
aearch
pleasant hill , ca
driver side rear inside seat moulding 40.00
good shape smalll scratch
lens is perfect amer passenger side 15.00 SOLD
good switch 25.00
driver outside rear window trim SOLD
OK IM AT [email protected]
ok
switch, lens and plate sold
ok i reinstalled the rubber and weatherstip on the interior
rear outside chrome trim ok
under seat trim
one is real good shape pass side
driver is fair
40 PAIR
[email protected]
emerswitch still avail
Also top window
Both sides of top front window trim
35 for the pair
bump, for Alan.
got my three parts from Alan today, he posted the items super quick and they arrived in just one week here in Australia. parts are good.
thanks Alan.
Gavin
more
oem rotary 74 cs air cond compressor and bracket 100.00
AIR CLEANER 74 USED ON WEBERS ALSO 75.00
ZENITH LINKAGE BAR 5.00
SPARK WIRE CONN 6- 15.00
WTR PUMP PULLEY 10.00
74 OEM DISTRUBUTER 50.00
HEAT SHEILD 5.00
WATER OUTLET 5.00
Alan, I'm interested in the compressor and bracket. Still learning about AC stuff. But I'm assuming this will bolt up directly to a stock m30? Who is compressor manufacturer? Has compressor between used recently? Leak free?
Stock
This came stock with the car i know cause its one owner ill send pic
HERES THE BRACKET I SPOKE TO THE ORIG OWNER AND HE NEVER REPLACED SINCE THE SHOWROOM FLOOR HERE IT IS WORKS
NICEW AND quiet not the cluncking yorks
also the hoses are stock that go to the dryer and firewall
part number bosch
0140-903-505
YEP TIGHT AS A DRUM NEVER LEAKED
GUARANTEED
HERES THE OEM PART LINK
Pretty sure that is a Bosch compressor. It is the same compressor that is on my '74 3.5 block (expanded to 3.9 via boring and stroking). Mine is going to be replaced by a Sanden, as it has significant leaks!
