Big Brake Kit From Ireland Engineering (Front only)
steve
San Francisco USA
I have a big brake kit made by Ireland Engineering. It is this kit only with different calipers AP instead of WilWood.
http://store.nexternal.com/shared/S...oreType=BtoC&Count1=124523341&Count2=41663765
The link doesnt seem to go directly to the item. Choose e3/e9 then brakes then the 2nd item from the top.
I have close to $2k into this kit. And will let it go for much less. I would like to get $1k for it.
Be for warned. This is not just a straight bolt on application. To bolt on and connect the calipers you have to do 1 of 2 things. Either plumb the existing lines into a T so you have only 1 line going to the calipers. (stock has 2 and I have the parts needed to do this). Or Change the master cylinder from a e28 with single lines. (This I dont have)
I had it hooked up with the lines T'ed. I found that their was to much braking going to the fronts and they were not balenced. Which was tearing up the pads and rotors.
To correct that would probably require a bias valve or going to the same calipers front and rear or both. It would be best to work with Ireland Eng with that.
I scraped the project because it became more than I wanted to do. My e9 isnt stock and I have already had to iron out a lot of modifications and I just didnt want to open another can of worms.
So having said all that if your up to the task you could get this part of it a lot cheaper than what Ireland sells it for.
So I have all this stuff in my garage gathering dust for the last year and would like to move it.
Ireland Brakes
Hi Steve,
I too have the Wilwood brakes from Ireland and wouldnt mind a swap to the AP calipers. Please PM me ([email protected]) and we can discuss the issue. Keshav
