GGR
Hi all,
as many 3.0 CSI owners, I have considered upgrading my car with 635 CSI parts: engine, 5 speed gearbox and LSD. But by browsing through the forum, I realized there were more advanced options, such as combining the B35 head with a M90 block using a B35 crank, which gives a 3.65L engine with bigger valves. My first question is to know if it wouldn't be simpler to bore a B35 block and fit M90 pistons to reach the same result. It would save the purchase of a M90 engine.
I went on browsing and found a link to Metric Mechanic. They develop a 4.0 litre engine. I tried to get the bore and stroke specs, but the only info I was able to find is that for a 3,9 litres the use a 90 mm stroke. Knowing that the 3.3 Li had only a 88.4 mm stroke, I wonder which crankshaft they are using...
Is there any experience on this board with the use of a Metric Mechanic 4.0 litre angine? What is it like?
Thanks in advance
Thanks in advance
