BMW E3 E9 Sideloader LSD - $1,000
SO CAL
Offered is a sideloader LSD in a 3.45 ratio. This diff did not come from the factory as a Limited Slip Differential. It was converted using an appropriate LSD spool. It does not have a painted "S" on the case and does not have an "S" stamped on the case. The numbers on the case in the usual spot are 11 and 38.
$1,000. Local pickup only. Located in Costa Mesa, CA zip code 92626
europartsmonger at yahoo dot com
