G
guanshee
Guest
I plan to swap my 3.0 cs 5-speed engine to a m30b35. Does the m30b35 engine have to be a manual or can can I use a m30b35 from an automatic donor.
Thanks..
Thanks..
One mechanic told me that engines from automatics are great because it is hard to abuse them in terms of driving them hard and revving.I plan to swap my 3.0 cs 5-speed engine to a m30b35. Does the m30b35 engine have to be a manual or can can I use a m30b35 from an automatic donor.
Thanks..
Downside is then you need to check for cam wear due to the oil pressure being insufficient at low revs on the front and back lobes.One mechanic told me that engines from automatics are great because it is hard to abuse them in terms of driving them hard and revving.
Good point. My mechanic was opining on an engine for a 4 cylinder E36...Downside is then you need to check for cam wear due to the oil pressure being insufficient at low revs on the front and back lobes.
