bavarian
- Messages
- 204
- Reaction score
- 47
Hey so I’m currently building a b35 for my e12 , these questions are more about the old m30 so it should be very similar to the one of the e9. I am keeping the motronic 1.3 intake
#1 can the b35 powersteering pump be used to power the old style racks and which way would you go old or new?
Can the old powersteering bracket be bolted to the b35 block , if you go old power steering pump should you go with an old style water pump pulley will the belts line up?
#2 I have the early style oil pan and the early style pick up tube , the early style pick up tube bolts up to the main cap for support in the old engines but there’s no spot for it to bolt up in the newer m30s, do people leave it just bolted to the oil pump with no support , I do have the top old style main cap and longer bolts for the base in which the old pick up bolts too I could adapt it but I won’t unless recommended,
#3 has anyone gone with an e34 new or rebuilt ac compressor instead of the sandem , it seems available for not too much ?
#4 for the people who have to 1.3 motronic where did you hide the computer the harness seems a lot shorter
#5 would the Ireland engineering crank oil scraper work on a b35 with the old school pump pick up
