BMW roundel 51141836500 from CSL rear spoiler
Ulrich 3.0 CSA
Germany
Hello all,
I am searching for: 51141836500 roundel at rear spoiler from 3.0 CSL (No. 13 at attached drawing)
The roundel is 71 mm diameter and flat! So any other BMW roundel wich is nearly 71 mm diameter and flat can also be used.
Thanks for any offer
Ulrich
70mm roundel
You can also try part #51.14.7.721.222,flat 70mm rear trunk emblem for a Z3, should be readily available.
thanks, krauser
Thanks for all the hints.
Yes I can use the Z3 roundel, but I need an "old" roundel which is not flat at the blue and white parts.
I enclose a foto
Ulrich
I struggled with this.In the end I found that putting the diameter into ebay got me some period badges that were very close. From memory mine is from a 1600 and is period correct.
Someone sent me a DM asking about this, I have one on an original rubber-lipped motorsport part. I'll see if I can shovel out to the shop in the morning, pull it out, and post a snapshot
