so i went to both replace the thermostat and water pump (upgraded to 9 blade fan variety) on my fathers engine transplant (engine still on stand) and broke no less than 3 bolts. 2 on the thermostat housing and one of the water pump studs. in researching the best way to remove said metal my plan is to first try the reverse drill bit method...followed by the last ditch "easy out" scenario. final course will be to retap and helicoil. anyone have any advice? i read somewhere to heat up the metal (torch) a bit before my efforts. i'm hoping the fragile bolts are not a sign my donor engine was mistreated in its former life. anyone?
TIA
TIA
