Gruppe,
I removed fuel tank from my 74 CSA a few weeks ago. It came out from under the car. Two brakets bolt underneath and hold the leading edge lip of the tank and two bolts go through the lip on each side and screw into the edge of the tank opening.
The manual says the tank is removed from inside the trunk. Does any one know when this changed? Will the "lift out" earlier tanks fit my car.
Realoem has no listings for the two brakets. Also, on my tank the filler neck and tank are one piece. There is no hose conection to the filler neck. Realoem shows the two piece tank/neck for my car.
I have my tank at a shop that will totally clean fill rust holes (my tank has a dozen pin holes) and reseal it for $350.
It will be as good if not better than a new one. http://www.gastankrenu.com
Before I give them the go-ahead I was wondering if any year e9 tank would fit my car
John M
John M
