brackets
de coupe
arizona
Hello, I do trust that every one had a good new year.
The question that I do have is one concerning the brackets for a L-block 3.7l. The brackets for the alt, power steering, a/c compresssor. And yes I do know that they didnt make a 3.7l But if you use a U.S crank and 144mm rods and bigger pistons it end up being a 3.7l. Any information that you can share would be great...Thank you
I was able to use the same brackets from the original CS M30 and apply them to a M30B35 without issue. Just swap the brackets over while the old and new engines are out.
