I recently picked up '71 2800/Bavaria that had been sitting in a garage, not driven for 20 years. I rebuilt the whole brake system - rebuilt all calipers (rear disk brakes), and used PMB Performance for reference, among other sites. I installed new hoses, new master cylinder (2nd new one), cleaned out pressure regulator valve, unclogged a couple hard lines, and got all the old fluid and debris flushed out. Following the factory guidance on bleeding procedures, I bled using the 2-person manual method, vacuum method, and lastly a pressure bleeder, so now I have a steady flow of clean and air-free fluid at all calipers. Probably put 1/2 gallon of fluid through the system, and yet, my pedal is still very soft. I have a '72 E9, so have some experience with these brakes, and know sometimes it takes a while to bleed, but this seems excessive.
Has anyone else had a similar experience? Could air STILL be trapped in the system somehow? Or is it something else? Any suggestions on a path forward? (i.e. keep on bleeding?) I researched this a bunch, but not sure how to troubleshoot at this point.
Thanks!
Larry
Thanks!
Larry
