I have just overhauled all four calipers, replaced all four disks and pads, brake hoses AND hard lines (because the hoses refused to let go, I did not replace the long one to the rear).
All that was left to do was bleed the system, and here begins my problem:
Bleeding was done the old-fashioned way, one in the car, one at the bleed nipples. I started by bleeding the hard lines at the master cylinder to get fluid into the cylinder. Started with the side outlet closest to the servo, half a turn open, pedal in, fluid comes out, close, release pedal. So far so good. But both the bottom one closest to the servo and the front side connector don't release any fluid while following the exact same procedure.
No point in bleeding from the nipples since fluid isn't even getting into the lines.
And this was supposed to be the easy part of the job
What could be the problem? I am clueless and any help will be appreciated, so i can finally start driving again.
Believe it or not,
BMW's recommended version of brake bleeding is to pressurize the brake fluid reservoir and then individually tap all of the bleeder screws/nipples beginning with the farthest caliper from the master cylinder. So, if you have a left hand drive vehicle, you would bleed in the following order: Right rear; left (driver) rear; passenger front and then finally the left front. If memory serves me, the front four-piston calipers are bled Top bleeder, then inside bleeder finished by outside bleeder.
Despite the above, I too have used the foot pumping method successfully for many years. I am told that by using the foot pumping method on a less-than-perfect rebuilt or worn master cylinder you run the risk of eating an internal seal. The theory being that a used or poorly rebuilt cylinder barrel may have irregular wear since the piston seals rarely sweep some parts of the cylinder. Same argument applies to clutch hydraulics.
I must apologize but your post is somewhat confusing. Apparently you attempted to bleed the master cylinder but you are unable to get fluid flowing from some of the master cylinder ports. You do not mention if you replaced or rebuilt the master cylinder or you are using the one that may have previously worked well.
I cannot tell if you are cracking the retaining nut on a line and you just fail to see dripping fluid. If this is the case, maybe you have not cracked the nut enough? In fact, I would pull the line completely from the cylinder to remove all doubt. If this does not provide any success, continue reading.
Is it possible that you never fully primed the pump? This is not usually necessary, but I have actually witnessed a mechanic immerse the entire assembly in brake fluid to force all air out of the system and prime a troublesome master cylinder. Again, this is not my practice, nor is it my suggestion, but I bet it’s effective.
In any event, if you cannot prime/bleed your master cylinder it is dry and the question is why. Could it be that although you have the reservoir hooked up feeding fluid to the master cylinder, the fluid is being restricted to one area of the master cylinder? I recall having a similar problem with an entirely different car. It turned out that a small brass washer was improperly fitted under one of the rubber grommets designed to cradle the rubber feed tubes. The washer obscured the inlet hole in one of the master cylinder ports so that the master might have become “moist” rather than full of fluid.
There is a washer used in your master cylinder "no 9", and if it is the correct size, this is a non-issue. However, it is not that hard to look to make sure the port is not covered by pulling the feed hose. It is possible that the wrong washer or just some debris is blocking the inlet orifice.
If your master cylinder is partially dry and if it is not a restriction of fluid to the master cylinder, the only thing left is
a piston seal is not sealing due to a defect in design or installation or cylinder wall irregularity - any of which means removal and replacement. It may not happen often, yet it happens. I recently had to install two new master cylinders for a well-known Japanese because neither master cylinder held pressure. The third part we tried worth perfectly.
One more thought. If you were describing no fluid from a caliper nipple, my first suggestion would be to examine the nipple for blockage or even distortion. They are easily distorted and get plugged. Then I would see if there is fluid getting to the caliper. If that did not work, I am afraid I would have to pull the caliper and mechanically fish out any blockage or make sure the caliper is not frozen.
The master cylinder is not much different in that there may be an internal defect or you have got something pinched or restricted in the inlet or outlet.
Sounds simple enough, unless you are stuck on the side of the road covered in brake fluid. :wink:
Hope this helps.
