Last Tuesday I decided to tackle what I thought would be a quick repair on my coupe. My steering wheel had a bit of play in it and I was told by a few people that loosening the nut at the top of the steering box and slightly tightening the bolt with a screwdriver would remedy the problem. This was true, I was able to accomplish this. The mistake I made was assuming this would be an easy job. What I thought wold be a 1 hour task turned into a 5 hour challenge. I ended up removing the master cylinder, moving the booster and the power steering reservoir and also removing the coolant expansion tank. After putting everything back together and bleeding the brakes I now can hear a hissing sound from inside the car when depressing the brake pedal. The brakes work well, and once the car has been running for 20 minutes, the hissing pretty much goes away.
Was there a seal or gasket that I missed? Was I supposed to use any type of gasket maker or sealer?
Thanks in advance for the advice!
Mike
Mike
