My brakes suddenly became very difficult to operate. The brake pedals is very hard. I have performed the test to press the pedal 10x and then start the car. There isn't any pedal drop when the car is started. Also, I have checked the in line valve in the booster hose and it's pulling suction on the booster end. In addition, have checked each corner to make sure that fluid is getting to each bleed valve with pressure from my Motive pump. At this point, it appears to be the booster.
Are there any suggestions from those that have removed the booster?
It looks like the (4) nuts need to be removed , the bolt on the brake pedal, and the MC needs to be unbolted from the booster. Are there any other items that need to be removed to gain clearance?
