E9Pilot
I have been hunting electrical gremlins on my 1972 3.0CS for two straight days now and am hoping the experts here can help me out with some diagnostic prowess.
Symptom: Brake lights and blinkers are not working at all. The hazard flash, but no turn signals.
Cause: When trying to find a switchable power source for a small Air Fuel Ratio gauge, the #4 fuse blew when I grounded something I should not have near the steering column. It was the resistor under the cover labeled 122 on the electrical diagram and 30/31a on the resistor itself. It's right next to the ignition switch. The #7 fuse never blew. This has made the brake lights and turn signals not work. ??
I replaced #7 fuse anyway and still no lights.
Diagnostic efforts: Chased the Green/black wires from the brake switch to a relay #53. No power when the car is off, which is normal, but the power is there when the key is turned to the on position, also normal. The kicker is that I get no power on this circuit when the ignition is on and the brake switch is connected. The fuse remains intact. Tested wire continuity, good there and all the way to the lights via Green/Red wire. Light bulbs are good. The switch has continuity when open, which is normal.
what would cause the no-power situation after the brake switch being connects with the ignition on?
By the way this circuit worked flawlessly before. Is there something I am missing? Thanks in advance for any help!
