Baikal Bimmer
How hard would you have press to lockup with stock vs wilwoods?
Yes our front spoiler does have air ducts. So do we agree that for more race/track related applications the stock brakes are inadequate? I was under the impression that their adequacy was in terms of ‘in 1972 they were adequate’ not 2020
I did a a few CCA track days back when our cars were relatively newish. The stock brakes did fade, so I switched to a Ferodo Metallic pad, and it helped a lot. But then my brakes were terrible in the cold, almost non-existent below 30F and squealed.
So. I’d say 40 years ago the E9 brakes were inadequate for track days.
Today, both tires and brake pads have improved a lot, but I don’t know if one has outpaced the other.
How fast and aggressive are you on track, and which tracks. Are you planning to drive?
John.
For autocross I’ll guess stock brakes are ok, but I don’t know the type of courses CCA lays out in CA.
For tracks, you might first try a high temp street pad compound as a way to judge the size of the performance gap which needs to be addressed.
If you only have minor fading, some simple ducts with stock backing plates might be all you need.
If you do upgrade just the front, you can calculate the brake bias change relative to the stock system as long as you have a little data on the pads and calipers. This and a day some brake testing (with warmed up tires), will give you a quick idea of whether or not you need to replace the existing rear brake proportioning valve with an adjustable.
The other advantage of installing an adjuster is the ability to compensate for a wet or cold track (tolerates higher rear bias, eg less front bias). But I’d you are at an event where the track conditions are changing while you drive, you’ll want the bias control inside the cockpit and at hand.
I was at an event recently where this was fairly important. One guy forgot to take out rear bias as the track started to dry and ended up spinning when the rear broke away sooner than he expected. Fortunately, it was just a light kiss on the barrier, but unfortunately it went down the entire side of the car :-o
The description of the Wilwood conversion says something interesting:
Note: These calipers are single line. You must either switch to a single line master cylinder like BMW 34 31 1 150 229, or “T” the hard lines then run 1 line to the caliper.
It seems that if you took the "T" approach, you would lose the benefit of having dual circuit brakes. Wouldn't it be better to cap off one line and connect only the other to the Wilwood front calipers? Or am I missing something?
