Took the driver's side door panel off to trace a rattle I hear every time I close the door. Found the culprits laying near the bottom of the door. Whoever replaced the door brake must have forgotten to remove these:
While I had it all opened up I decided to remove the window mechanism to clean and re-grease everything and to refasten the chrome strips onto the door card.
Was surprised to find a broken coil spring:
One question I have is does this spring help raise or lower the window?
I don't really notice any real speed difference raising or lowering the window. I only notice the window slowing down a bit on the last inch of upwards travel with the door closed, it doesn't seem to slow down as much with the door open.
I think I might need to adjust the window, looks like it top 1 inch of the rear portion of the window presses harder against the vertical rubber weatherstripping of the rear window than the lower part.
Of course the last question is if the spring is required, where is a good place to check for a replacement spring? Thanks
