hank szeto
New Member
- Messages
- 3
- Reaction score
- 0
1974 3.0csi: Any ideas what causes the bucking at RPMs below 2,000? Problem goes away with I down shift (increasing RPM). Seems like it is starving for air or gas.
Hank
Hank
Hank,
SFDon is on this forum, hopefully he will read this and weigh in. you might try running BG44k injection cleaner. you put it in the gas tank -
since this is a recent development, you might should check the fuel filter - might have some water or trash in it. taking the injectors out and having them flow tested and cleaned usually means you have to send them to somebody who does that kind of work.
scott
I agree. One of the first things to do, if in doubt, is to replace the filter. Especially if you are sensing a starvation issue. I once spent many hundreds of dollars and dyno time chasing down a problem that turned out to be the fault of this $10 part.
