Bumper clips
aearch
pleasant hill , ca
Bumper infill
Looked around no luck
i need the square inset clips for the bumper trim on the 74
cs
i repaired mine
so if you own a 74 or 75 and have these infills
anf you see a curved indentation on the top
it means the plastic cover underneath has separated and the metal frame inside is rusting - you can cut the lower plastic loose and expose the metal frame to
clean or replace
i just cut new metal infills and weatherstrip adhesive them back in
also heated the plastic surface to get the creases out
it works pretty good then paint them ald and other plastic you
want to restore
with flat black then just use meQUIRES 40
rubber protectant
they come back brand new
