MMercury
- Messages
- 481
- Reaction score
- 5
This question concerns the use of bypass oil filters on an M30. Such systems are widely used in commercial and marine applications. They have been around for decades and supplement the stock oil filtration system by scouring the smaller unwanted particles from the oil. I am not suggesting a bypass filter is necessary for normal passenger vehicle operation nor am I attempting to debate the relative merits of such a system. However, I am curious as to any applications specifically fitted to an M30 or even M10 engine.
The post is prompted by a chance observation of what appeared to be an oil bypass system fitted to an E24. (Driver was checking oil and drove off before I had a chance to observe more closely and ask a few questions.) This was shortly after reading Pamp's post about a different style filter assembly http://www.e9coupe.com/forum/showthread.php?t=5808.
I have seen an M10 fitted with a Frantz bypass filter that, from memory, was fed by a small port off of the oil filter housing. Anyone familiar with running the Frantz or similar bypass system (Amsoil) on an M30? What is the common low pressure source, the oil pressure sending switch at the back of the cylinder head? Common return location? This subject received very brief discussion in another post http://www.e9coupe.com/forum/showthread.php?t=5326 Gwittman, any pictures or further details?
FWIW, here is a pic of an installation marketed by Amsoil on an E30:
see: http://www.amsoil.com/bypassfilters/viola_mark/index.aspx
http://www.frantzoil.com/home.html
Thanks in advance. :wink:
