caliper question
IIRC...
Pete, seems to me from back in my tii days, that not only the e12 calipers but also calipers from early 6 series will do the job...?
"Verification is left as an exercise to the reader"...
On 5 bolt cars, the calipers from e3/e9 and e12 (early e24 are the same) are interchangeable. The only difference of importance is fitting vented vs. solid rotors.
The mount bolt size, spacing are the same on e3/e9 and e12, and the pads are the same, and unless I'm way off, even the pistons are the same. Just a little bit of difference in the external dimensions of the casting.
For reference, my early (10/74 prod) e12 had been swapped to CSi vented rotors and CSi calipers. I replaced the calipers with a rebuilt set for an e12, they were a straight bolt on swap.
If you can fit e12 calipers, they are CHEAP from places like Autozone.
