Usually, this means a drain on the battery through the voltage regulator on the fender. You're warning light may stay on or be very dim.
If you have a electrical meter you can measure the loss at the battery. Then disconnect the voltage regulator to see if in fact that component is the problem.
If not, taking out a fuse one at a time while measuring is another way for determining a loss to narrow it down to a circuit and device.
