decoupe
(deceased)
As the last step in the conversion I took the car to a chassis dyno tuner recommended by SDS engine management guys. I asked for a factory type tune with cruising at any rpm set to approximate AF ratio in the high 14 range and with throttle input in the high 12's/low 13's (averaging almost exactly at 13).
At the end of 2 1/2 hours of set up and tuning my rwhp is up just under 10% at the rear wheels. This was on 89 octane and we had to dial back some advance due to pinging so when I get some better gas in it I'll advance a couple more degrees and pick up another 3 - 5% at the top end of the curve. No changes to the engine build in this conversion so a good basis for comparison. 42,000mi since rebuild on 3.5litre, 9:1 pistons and 282 cam.
In some ways I'm disappointed but I think this just proves that a well set up 38/38 weber downdraft and good ignition controls (petronix and other things) gives great results for not huge amounts of money (a relative term). So enjoy the webers Bill, I'm sure you will like them.
The hp and torque curve for the two systems is very different with the EFI very linear to 5200 and then rolling off to redline (which I set at 5800). The webers produced a steeper hp curve to peak at 4500 and has a some power advantage up to 3800 but then starts to flatten (almost horizontal from 5000) to redline. Where the webers really shine is in low end torque with real meat and potatoes right from 2500 up to 4000 where the efi has no particular sweet spot -very linear.
Where the EFI really shines is managing changing driving conditions and engine set up. I drive in altitudes from sea level to 7500' and any re-jetting in the carbs beyond the idles is a total PIT (to me anyway). If you live on the east coast or SoCal this probably isn't an issue but in Denver or Canmore it is.
The webers also are throwing a lot of gas into the mix regardless of throttle input so mileage is not great and they do love to be a bit rich to 3000 but that's how you get that sweet low end torque. On the other hand the drivability under any conditions and smooth power to redline with efi is very nice but the best power is higher up in the rpm band and that is how you get tickets.
I'm very happy with what I learned and what I've ended up with. Except one thing - throttle whistle. Something new to solve.
http://www.google.ca/search?client=...8&oe=UTF-8&redir_esc=&ei=cAoUTKuYGKWkM8iWuNoL
Doug
Doug
