I haven’t seen it posted yet, but Son of Cobra is now selling carbon fiber hoods and trunk lids for e9s.
www.sonofcobra.com
He's doing that for 02's, so perhaps that is in the works.Very nice. A carbon roof skin would be cool as a decent skin these days is hard to find!
Can he make carbon fibre E9 front wings also ????I haven’t seen it posted yet, but Son of Cobra is now selling carbon fiber hoods and trunk lids for e9s.
SHOP MOTORSPORT — SON OF COBRA
www.sonofcobra.com
Would their be a demand for carbon fibre front E9 wings ???As long as has a pattern to copy.
For sure someone could technically make a copy: I even have an NOS one that could be used as a template for anyone interested ((not for sale..)), but the wings are kinda structural to the front end, being welded in on all sides. Can carbon fiber be bonded (glued) to the steel structure in a similar strong manner, with an acceptable panel fit?Can he make carbon fibre E9 front wings also ????
Oof, these look so good. ~$4400 for 61 lbs weight savings though? The cool factor alone may be worth the price.
Absolutely. I used structural panel bonding on my 914 build. Modern epoxies are incredible. Now, I'm not a trained engineer but I've done enough work with steel and composites that, in the case of replicating structural steel parts in carbon, the issue is about design - you can't always do a "shape-for-shape" copy and expect the same strength/performance. In a non-structural application, like those lovely hoods, sure, one-one works just great. But look at steel vs carbon bicycle frames, for example. The carbon is shaped far differently, has the fibers layed up in different directions and/or in different thicknesses and weaves in different areas, based on the desired/required strength or flexibility needed. So, it's likely possible to do a carbon E9 fender that looks E9 on the outside, it just probably won't look E9-like on the underside.For sure someone could technically make a copy: I even have an NOS one that could be used as a template for anyone interested ((not for sale..)), but the wings are kinda structural to the front end, being welded in on all sides. Can carbon fiber be bonded (glued) to the steel structure in a similar strong manner, with an acceptable panel fit?
I have zero knowledge on race car preparation, but it may be standard exercise there?
Based on the published numbers, this doesn’t include the torsion bars. The front weighs 12lbs, so figure another 14lbs F/R, totaling 75lbs. That is IMO a hefty number to shed when you’ve already trimmed the fat.
