jhjacobs
Last night I installed the front set of my new springs, spring pads, Bilstiens, and swaybars from our good friend Carl. Really nice stuff. My front end dropped 1" / 2.5cm exactly (useless spacer thingies previously removed).
Installing the shocks and springs was painless. I put the front of the car on stands (windows cracked), removed the old swaybar, and then jacked each wheel up (under the main ball joint to apply pressure to collapse the spring. I then applied my $37 spring clamps from Advance Auto hand tight (no need to compress any more) and removed the shock nut with an impact wrench (27mm I think). I then slowly lowered the wheel and the whole assembly pops out. I was just able to get the top of the shock and spring to clear the wheel well. The spring just lifts out and the top of the shock has a big spanner nut. To loosen the spanner I pushed the springless strut back in to position and jacked it back up into the tower; this let me get nice leverage. The new springs are a bit shorter and I did not need to compress the to get them installed.
All in all, the spring and shock work was only about 1.5 hours. The swaybar on the other hand is another story. It should be simple. Two bolts for the bushing linkages and two for the pivot point brackets. Yeah, right! :evil: First, the new brackets are too deep and won't slip into position. I had to grind off about 1cm from the back; this is hard steel and it didn't like grinding. Second, the slot for the bolt is not deep enough and I had to drill it out about 2cm more. Finally, for some reason the manufacturer put a square tube on top of the bracket which absolutely would not fit in the space alloted; I think this is designed to allow a 1/4" ratchet wrench to be used to compress the bracket -- more grinding. Even with all of my modifications it took about 4 hours, lots of possum grease, and every curse word I could think off to install the freaking swaybar. Perhaps I'll ask Orangener for some German curse words which may work better than the ones I used. At leasts it installed now and if it would stop raining I'd go for a spin.
I will say that this swaybar makes the OEM swaybar look like a joke and lizard green color is, well, unique. :roll:
More to follow on the rear installation.
