This may be handy in this caseView attachment 51480
I have no experience with RHD . But have been in similar position before. Try soaking a micro fiber cloth with penetrating oil. Hold the soaked cloth in such a way that you can squeeze the penetrating oil over the nuts you want to open.
Let it sit for a while and come back in couple of hours and use a new micro fiber cloth and wrap it over the nuts now you will have a better grip on the nut (believe it or nut) you will have much more leverage . If that didn’t work another technique is try to tighten it a bit . If it moves in that direction then you are closer to a result. You can go back and forth tightening and loosening until it frees up.
Best wishes from Edmond Oklahoma USA.
By the way My mother in law just landed in Melbourne to visit her brother!!!!
Yah, she lives in Kuala Lumpur, Malaysia . Hot and humid all the time. She will definitely enjoy it...That's not a bad idea. Will give that a go.
Was 20 deg C in Melbourne today, pretty nice
Only a 50 min flight to Tas, they wont want to miss it..
W
Yah, she lives in Kuala Lumpur, Malaysia . Hot and humid all the time. She will defiantly enjoy it...
It worked for me like a charm. It’s like having your flexible tiewrap wrench!That idea with the glove is genius.
Will give it a go.
Another technique is to use loose leather gloves!
THANK YOU for this invaluable procedure!!!I put instructions for an LHD CS here:
No wes , the screen does NOT have to come out to remove the dash, it genuinely is an easy job.If you lived a little closer I'd demonstrate my grip strength via placing my hands around your throat
There is no way those nuts are going to be moved via coming up from below on my car - suspect this in an issue for RHD's generally.
I've now pulled the centre consul looking for the mounting screws so I can pull the cowl of the top of the gauge cluster to try and get in that way.
They also don't appear to be in the same positions as for a LHD. Starting to think half the bloody dash is going to have to come out
From memory the screen needs to come out fr this to occur?
