CLose ratio trans, which guibo?
Bavman
Hello
Did a search and found zip....which guibo are yall using with the CR box? I hav e a friend that is using one in an early e12, the flat side with matching short nose driveshaft is 1/2 short at the center support mount in the body, the thick rounded guibo works with the longer snout driveshaft but want to make sure there is not some issue using the thicker guibo....like shifter interference..
Al Taylor
