Wondering if anyone has had this experience; I am putting a Getrag 265 5 speed out of a 1980 633 csi into my 3.0 cs replacing the automatic. I have the transmission and purchased and resurfaced a flywheel to match the 1974 engine and also purchased a new pressure plate, disk, TO bearing, etc. Both the old and the new disks are Sachs and both have the same part number however there seems to be a significant difference in the thickness of the splines on the new disk and it will not fit on the input shaft from the transmission. It's not a tight binding fit, it will not go on at all??. I counted the splines and measured with a good MIC and the splines just seem to be to "thick".
Does anyone have any ideas? I attached a pics of the transmission in case that will help with this mystery.
Thanks!
Thanks!
