Clutch Master Cylinder
BlauMitWeiss
All, My wife would like a 5sp in the CS, I have a 265/6 which came with my S14(2002 project), but it will require the speedo drive etc.(reference article is excellent)
I will need a flywheel, pedal kit and of course the Clutch Master Cylinder. (will try the auto drive links)
I picked through the articles in the tech section and learned much, except, if and where I can get an actual, genuine CS master cylinder.
Are these available anywhere?, I suppose I could deal with a used for rebuild, but that would be a bother. Is there anything else that kinda fits? Alfa, Peugeot, VW, Audi?
Any guidance is welcome.
B..M...W...
The Clutch master cylinder from the e3 and e12 sedans is identical.
It should have a 22mm bore, and can be easily reconditioned by your local brake specialist before installing..
Thanks Bill, the drawing on RealOem suggests diferent master cylinders. I will chech that out.
By the way, I saw the pics of you 3.0 and '02....very sweet.
B..M..W...
