Laurent1602
Hello,
Some days ago I refreshed the oil in the hydraulic system for the brakes and the clutch from a 3.0 CSi (1974). When I left the old oil out, I found there came out very little, but I didn't care to much.
When I wanted to bleed the clutch slave cylinder with the new oil, nothing came out! We set pressure on the system but it didn't help. We checked all the connections and pipes but they were fine. So we ended up with the head cylinder beeing the problem.
With the compressor on it we can blow air through the cylinder in the direction from the reservoir to the slave cylinder and not in the other direction, so far so good. Because I could blow air through the cylinder I thought it was fine again. We installed it back, but again, no oil came out...
I suspect the piston in the cylinder but I'm not sure how it could cause a problem and how to fix it. Does anyone can help me?
Thanks!
Laurent
P.S.: I know my English ain't perfect and I'm sorry for that, but I think it's good enough to understand?
Thanks!
Laurent
