dascoupeguy
I am having to lengthen the pos and neg coil wires in order to fit the coil to
its usual position in the upper right corner of the engine compartment. I have a
motronic 1.3 system and the coil wires are to short. The 2 pos wires (green) are
no problem (standard type wires). My issue is that the neg wire appears to be a
very thick black wire that has a very thick shielding of some sort. It appears
have a metal shielding of some sort like a type of co-ax wire. It is the top wire in the pic.
Before I go cutting it all up, is this a special shielded wire? or am I reading
to much into this.
Help before I go snipping away! Thanks, DCG
to much into this.
