Hi guys, i did a good bit of searching and googling but to no avail so here goes. The cold start valve is not working on the car. If i put 12 vots to it it clicks and petrol dribbles out on a bench. On the car no sign of petrol and there is good pressure in the line.
I swapped with another CSV that is good and same thing. So i went after the thermotime sensor and the cold start relay - I swapped both of these for good or at least Im 90% sure good units - still no petrol spray :-(.
I tested the continuity between the CSV and the relay and it is good and the earths seem to be good too.
I also cleaned the ECU connector under the rear seat.
Any suggestions now?
It is 10-20 degrees celcius here and i understand it should work below 35c?
Any help would be great so i can cross another thing off of a very long list!
Regards,
Rohan
Regards,
Rohan
