compression readings
Although I rarely use them, I have a number of different compression gauges, some of which translate pressure readings into "approximate" compression ratios. I just seem to recall that 155 lb/sq.in., is translated/depicted on one of the gauges as being slightly above 8:1.
As noted, temperature may make a difference in readings as might the condition of the battery for cranking speed.
FWIW, I asked a friend to look at the "technical data" from the blue notebooks. He read the following: "good above 11(bar)/156 ; normal 10 - 11 (bar) /142-156; poor below 10(bar)/142". Again, as noted, different gauges are calibrated differently and even old-expensive gauges can be out of spec. I suspect there are some explanatory footnotes to these numbers - but they put the subject engines readings in the ballpark.
Parenthetically, the last time I checked the compression in my e9 I obtained 190 -195 lb/in2 readings. I used aftermarket pistons advertised at 10:1 compression ratio. I thought that was a bit high, and repeated the test with a gauge designed for diesels and obtained the same results. I can't really explain it except that different gauges may provide different results. As you gents pointed out, consistency between cylinders is every bit as important as high numbers. :roll:
