CS REGISTER DECALS ARRIVED
CSteve
Bucks County, PA
They arrived the other day, look beautiful, of course. I put together the directions below from four different knowledgeable sources after struggling to apply one to my coupe window. Knowing nothing about decal installation it was frustrating to say the least.
Those of you who know how may skip to the end of the directions.
1. Clean the inside of the window thoroughly with a good window cleaner. I suggest a towel at the base of the window so no moisture gets inside. Dry thoroughly.
2. Use either water or the window cleaner, spray the surface of the decal lightly. Position where you want it.
3. Using a credit card or some other squeegee-like object press lightly from the top of the decal to the bottom.
One source suggested down and to the sides. I did not do that.
4. If there are any small "bubbles" of fluid try the credit card first then the sharp end of a razor.
5. Dry carefully around your new decal.
6. Enjoy. Show off.
They do peel off easily and can be reinstalled(I know from experience). The only thing is they tend to curl and are a bit more difficult to work with.
When I am finished putting them all in envelopes, addressed and ready to go to the PO, I will mail them all at once. I say that because it will take some time as I am a solo practitioner at this.
Other installation suggestions are more than welcome.
Steve Contact me at: [email protected] with any questions.
6. Enjoy. Show off.
bump
